November 8, 2015, 10:48 |
problem meshing a missile
behzad jabbari
Rep Power: 10 |
Hi, I want to simulate flow over a missile importing that from solidwork to gambit.
This missile includes some volumes : main part, front wings, back wings. I can't operate boolean operations to unite these volumes and then subtract missile from the domain to have a single volume, becasue there is virtual volume in the importing geometry from solidwork. How can I have a single volume in spite of the fact that there are real and virtual volumes in the geometry?? |
November 10, 2015, 01:17 |
Maxime Perelli
Rep Power: 41 |
As you mentionned you cannot perform boolean operations since you have virtual geometry.
Do you have the possiblity to extract fluid volume in solidworks? What kind of format did you import in gambit?
In memory of my friend Hervé: CFD engineer & freerider |
November 10, 2015, 07:35 |
behzad jabbari
Rep Power: 10 |
I solved this problem .I imported the solid file in the parasolid format.Now i have one volume and want to mesh it.
What is your advise for meshing such a complex volume? |
November 10, 2015, 08:45 |
Maxime Perelli
Rep Power: 41 |
display at least your geometry
November 19, 2015, 05:32 |
behzad jabbari
Rep Power: 10 |
boolean subtract, missile, volume mesh |
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 18, 2023 23:49 |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 07:21 |
Gambit meshing problem to following geometry | ahmadmln | ANSYS Meshing & Geometry | 2 | October 21, 2014 01:49 |
[ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem | dalecooper | ANSYS Meshing & Geometry | 0 | July 19, 2013 07:04 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 20, 2006 23:31 |
