Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] Flapping motion of airfoil
Old   February 26, 2012, 00:38
Default Flapping motion of airfoil
sheth roh
sheth is on a distinguished road
I am trying to model flapping motion of airfoil. My questions are
1. After some iterations there is negative volume error being generated so what should I do to avoid that.
2. Is my meshing scheme suitable for capturing flow perfectly (Image attached).
3. How do I mesh so that when flapping occurs in solver there is no negative element. Or any remedies for such problems.
4. I tried the remesh option available in cfx solver, but it rotational displacement about centroid or any other point is neglected in remeshing. See image [its from cfx manual], so any solutions?
Any help will be appreciated.
Thanks for time.
sheth is offline   Reply With Quote
Old   February 26, 2012, 20:59
Retired from CFD Online
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
If you mean that you move the nodes of the airfoil and that causes them to collapse elements in the direction they are moving, I would say you need to work on your morphing skills...
The morph needs to be interpolated over a larger range than one element... This way, as you move the airfoil, the displacement will be shared over a much larger range and all the cells in that range will only be affected by a small amount...
If the CFX solver has this capability, you may just need to learn to use it properly. Try asking this question in the solver forums instead...
How ever, I can tell you that the mesh is not sufficient, even for a stationary wing... Most of the interesting stuff should happen close to the airfoil surface (the boundary layer) or in the wake behind the airfoil. You have insufficient mesh resolution in both of these areas...
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   February 27, 2012, 17:29
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Here's a link of Mr simon performing a mesh around an airfoil. it's very well explained get some inspiration from there, hope it will help:
http://www.youtube.com/watch?v=tYrbScUH9RE
Regards,
New to ICEM CFD, try this document --> https://goo.gl/NEbygB
Ali
diamondx is offline   Reply With Quote
Old   February 28, 2012, 08:33
sheth roh
I agree with you both. I have kept meshing quality so low because I wanted to test if the mesh motion commands in cfx are working or not so I kept low mesh elements to reduce computation time. But should I opt for any special type of mesh if my airfoil has translational and rotational motion.
Thread Tools
Trackbacks are On
Flapping Wing motion balkrishna FLUENT 19 April 13, 2016 15:42
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
help for DEFINE_CG_MOTION for a flapping airfoil M.Sc_Student Fluent UDF and Scheme Programming 0 March 5, 2011 11:16
UDF for Airfoil in Circular motion (2D) sohail_27 Fluent UDF and Scheme Programming 4 October 4, 2010 13:36
Plunging airfoil + Flapping wing SonyCFD CFX 4 June 15, 2010 06:49
