Home > Forums > ANSYS Meshing & Geometry
[ICEM] igestotin batch command
Like Tree1Likes
  • 1 Post By stuart23
Old   February 27, 2012, 20:51
Default igestotin batch command
Stuart Buckingham
stuart23 will become famous soon enough
Hi Guys
Does anyone know what happened to the ic_trans_step_tetin command in Ansys 14.0? My script that worked fine on Ansys 13.0 no longer works with the new version. The command and error are as follows:
med> ic_trans_step_tetin /home/sbuc9/geo/BODY.stp /home/sbuc9/geo/BODY.stp 0 {} 0 {}
"/usr/ansys_inc/v140/icemcfd/linux64_amd/dif/iges/igestotin" {} "/home/sbuc9/geo/BODY.stp" "/home/sbuc9/geo/BODY.stp"
/usr/ansys_inc/v140/icemcfd/linux64_amd/dif/iges/igestotin_exec: Command not found.
Any help would be greatly appreciated,
Thanks
Stu
stuart23 is offline   Reply With Quote
Old   February 28, 2012, 04:05
Stuart Buckingham
Never mind, sorted it out. As is usually the case in anything Linux, the libraries were incomplete. For those who may happen to come across the same problem, try:
yum install libXt.{i686,x86_64}
yum install compat-libstdc++-33-3.2.3-69.el6.i686
PSYMN likes this.
Thread Tools
Trackbacks are On
batch command initial values test3r CFX 2 September 12, 2011 15:02
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 05:41
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
