-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Dynamic mesh for a pitching airfoil (http://www.cfd-online.com/Forums/ansys-meshing/98053-dynamic-mesh-pitching-airfoil.html)
bahram.raeisi March 1, 2012 18:19
I am new in using ICEM. I used GAMBIT and created a dynamic mesh for a pitching NACA 0012 airfoil by applying triangular cells around the airfoil. Later, I used this mesh and studied aerodynamic coefficients for a pitching airfoil by running FLUENT 13 in transient mode.
I need to create another mesh by ICEM and compare the final result with the result from the GAMBIT mesh.
As I know only created meshes by GAMBIT with O-type grids and triangular cells can have motion in transient mode in FLUENT. Then do you know if there is equal type of triangular cells in ICEM. How can I choose a O-type grids with triangular cells around my airfoil in ICEM?
Far March 2, 2012 10:41
Multizone meshing
