March 1, 2012, 18:19 |
Dynamic mesh for a pitching airfoil
Bahram Raeisi
I am new in using ICEM. I used GAMBIT and created a dynamic mesh for a pitching NACA 0012 airfoil by applying triangular cells around the airfoil. Later, I used this mesh and studied aerodynamic coefficients for a pitching airfoil by running FLUENT 13 in transient mode. I need to create another mesh by ICEM and compare the final result with the result from the GAMBIT mesh. As I know only created meshes by GAMBIT with O-type grids and triangular cells can have motion in transient mode in FLUENT. Then do you know if there is equal type of triangular cells in ICEM. How can I choose a O-type grids with triangular cells around my airfoil in ICEM? |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Dynamic mesh update problem. | David | FLUENT | 3 | March 15, 2012 05:02 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[mesh manipulation] Dynamic Mesh Diffusivity Problem | dancfd | OpenFOAM Meshing & Mesh Conversion | 0 | August 29, 2010 11:50 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
