Home > Forums > ANSYS Meshing & Geometry
[ICEM] Cylinder Meshing
Old   March 15, 2012, 11:10
Default Cylinder Meshing
mll3261 is on a distinguished road
I was wondering what the best process for using ICEM would be to mesh a cylinder. I wanted the circular surface to have a mesh that radially grows from the center. I have tried using ANSYS meshing but I could not get the circular surface to complete the radially mesh. I had gotten around this by using a small square in the middle of this surface and divided the rest of the surface into four pieces. I am now trying to find a way to get a purely radially mesh. I am new to ICEM and was just wondering what the process would be to complete this mesh, if possible, in ICEM.
mll3261 is offline   Reply With Quote
Old   March 15, 2012, 11:36
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
this may be helpful Meshing in Gambit for analysis of flow past cylinders
Far is offline   Reply With Quote
Old   March 15, 2012, 11:38
CRT
Carles
CRT is on a distinguished road
I think that the easy way is to make a o-grid and use the bunching laws: geometric 1 or 2. donīt forget to associate the edges to the curves at the top and the bottom of your cylinder.
it could be good that u check the tutorials.
CRT is offline   Reply With Quote
Old   March 15, 2012, 12:28
I tried following the tutorial for the 3D pipe, but I end up with just a rectangular mesh inside of my cylinder. I associated the edges of the squares at the end of the block to the circular curve. I have attached the image of the block and geometry curves, as well as the incorrect mesh.
Old   March 15, 2012, 12:46
Far
Sijal
There may be three possible problems
1. Edge association is not correct.
2. If step 1 is done, use edit edge >>> spline
3. Create four points on each circle and associate vertex to point.
To improve quality, create O-block as well.
Old   March 15, 2012, 16:54
Far
Sijal
I suspect you have made a very basic mistake about association. Check attached tin and blk files
Old   April 20, 2014, 13:42
Utzname is on a distinguished road
Hi, I am struggling with the same issue. I want to create a mesh, radially growing from the center. I am using KIVA and hence not allowed to use o-grid mesh.
Here a picture:
I am fairly new to ICEM and really dont understand why it is so hard.
When I am doing a partially circle ( i.e. 90 degrees ) the mesh is automatically starting from the edge.
Thanks a lot for your help!
Utzname is offline   Reply With Quote
Old   April 20, 2014, 13:49
Far
Sijal
Here a picture:
Create ogrid first. then merge vertices of inner ogrid.
Thread Tools
Trackbacks are On
meshing on cylinder fails ICEM potac ANSYS Meshing & Geometry 0 October 25, 2011 05:21
2D planar cylinder meshing problem saisanthoshm88 ANSYS Meshing & Geometry 15 December 27, 2010 12:14
[ICEM] (ICEM CFD) meshing over a cylinder vmlxb6 ANSYS Meshing & Geometry 6 August 11, 2010 14:37
Meshing inside a cylinder so that the edges contain more cells than the center Bertrand OpenFOAM Native Meshers: blockMesh 1 April 13, 2010 04:46
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
