April 27, 2018, 03:22 |
I wanna control this territory
seunghyeon, yun
Rep Power: 7 |
You can see large difference through circumference wise. I want to decrease mesh size of this part. tell me your tip~ Have a nice day!! |
April 30, 2018, 04:23 |
M
Rep Power: 12 |
1) Hide "show mesh" item
2) Choose a Layer and enable at least "Master Topology Visibility" -> you should see purple lines at the layer 3) Hit right-mouse button on a line close to where you want to change the mesh size 4) Use "Edge Split Control" and assign a factor by which you want to increase the number of cells (can be decrease as well) |
May 2, 2018, 21:09 |
I have a question.
#3 | |
seunghyeon, yun
Rep Power: 7 |
Thanks your reply. I have a question one more. I use ATM. Where is "Master Topology Visibility" ? To my knowledge, this is manual mode and ATM is strongest mode in TurboGrid. right? Have a nice day!! |
May 3, 2018, 06:58 |
M
Rep Power: 12 |
I tested it and it works just as I described.
Master Topology can be enabled in the respective Layer properties. Double click a layer and it should be in the window opening to the left. ATM is not "the strongest" mode, its just one of two options. It also has disadvantages, but in general gives high quality mesh. The purple lines in the image are the master topology lines. Right mouse click on them allows you to add a edge split control item to any line. |
May 4, 2018, 04:53 |
Thank you!!
#5 | |
seunghyeon, yun
Rep Power: 7 |
But, It's not easy~ I'll try to get mesh of good quality. Thanks again. Have a nice day!! |
May 4, 2018, 06:09 |
M
Rep Power: 12 |
I think its pretty easy ... however, glad I could help.
Display Modes | |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 06:41 |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 05:28 |
CFX FSI Fatal Error | unbanana | CFX | 0 | October 3, 2015 06:57 |
FSI: Pressure and Normal Force don't match with expected values | Geraud | CFX | 6 | August 21, 2012 16:34 |
Match Control and Symmetry Boundary Condtions in a quasi 2D calculation | peterputer | ANSYS Meshing & Geometry | 0 | May 15, 2012 09:53 |
