Home > Forums > ANSYS Meshing & Geometry
[DesignModeler] How to create "islands" within a layer?
Old   March 20, 2012, 02:20
Default How to create "islands" within a layer?
Eric S.
esend7881 is on a distinguished road
I am working Design Modeler and I am facing something I can't quite figure out, even with the manual. I was wondering if someone here may know really quickly.
Basically, I am trying to make a layer in the design moduler that has little islands in it.
Think of it like this: You have a 1" x 2" copper layer, but within the copper layer, you have mini 0.02" x 0.02" copper rectangles inside, each separated by an insulator.
So, the 2D layer, with little islands inside of it.
Any tips on how to make that happen?
I attached an image of what I made. Basically, I know how to create the layers and extrude them, but as you can see by the 2" x 0.02" strips in the middle, I don't know how to separate out the islands.
esend7881 is offline   Reply With Quote
Old   March 20, 2012, 05:57
Raja_Bhai
tauqirnawaz is on a distinguished road
It would be much more easier if you create it in SolidWorks, any way, in DM you would have to define separate planes for each layer and define the location of plane by adding Transforms. Then create sketch on that plane.
tauqirnawaz is offline   Reply With Quote
Old   March 20, 2012, 08:18
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
You can draw lines on the sketch of the target 2D plane, then split the surface with the lines to create the islands.
BTW, this is something like the solar module, with two reinforce strips on the back.
rikio is offline   Reply With Quote
Old   March 21, 2012, 01:03
Eric S.
Hmm.. I'm not sure if I follow this one. Do you know of an example I can base this on? (A link to an example that is, I know you mentioned solar module)
Old   March 21, 2012, 01:43
Eric S.
I think I may just do it in Solidworks, but a shame it can't be done that easily in DM. I consider my CAD to be pretty simple, its basically a mutli-layer rectangle with some islands on it.
Old   March 21, 2012, 02:24
Rikio
Do you want to select the two slim islands to set boundary condition?
Old   March 21, 2012, 02:29
Eric S.
If I understand your question right, I do want the islands to be electrically separated and able to analyze effects in them, independent of the other islands.
There will also be more than two, closer to 20.
Old   March 21, 2012, 02:56
Rikio
I am not sure your method to build model, but if it is right as the attachment shows, extrusion from sketch would help. And there may be no other more convenient way, as far as I know.
Or you need a separation layer under the small block to keep it unconnected from the base layer? If so, you can create a multibody part, assign different material to each body.And the mesh in the common surface would be consistent.
Thread Tools
Trackbacks are On
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 14:18
A question on "Specifying Boundary Layer Deformation Smoothing" didiean FLUENT 2 January 16, 2012 22:39
[ICEM] Can't create prism layer on 2D extruded mesh PedroC ANSYS Meshing & Geometry 19 April 19, 2011 20:48
Trimmer & prism layer peresah STAR-CCM+ 6 October 6, 2009 14:39
Help!!!: Direction / Normal of Boundary Layer JP FLUENT 0 September 9, 2008 18:16
