[ICEM] How to mesh the external waterflow of a MCT blade
Old   March 23, 2012, 02:32
Default How to mesh the external waterflow of a MCT blade
Hongbin Chow
zhbb is on a distinguished road
hello,everyone,I'm working on a marine current turbine (MCT) blade,it looks exactly like a wind turbine,except that it works underwater.
the blade got sections of NACA 634XX with really sharp trailing edge,and it is twisted. Now I want to mesh the fluid domain around the blade, a cylinder with a blade shaped hole. I failed meshing it in ANSYS mesh,so I think maybe ICEM CFD can do the job. how to split the block, or unstructured mesh? I am confused. someone help me? thanks a lot!
zhbb is offline   Reply With Quote
Old   March 23, 2012, 03:04
Far
Sijal
Your problem is similar to this one?
http://www.cfd-online.com/Forums/ans...mesh-wing.html
Old   March 23, 2012, 03:42
Hongbin Chow
thanks for your reply!!!
Old   March 23, 2012, 03:47
Far
Sijal
If yes, then you can follow this thread, otherwise we should start working in this thread.
Old   March 23, 2012, 05:31
Hongbin Chow
In my case, the blade is twised along the Z-axis, so it's not just a section extruded along the Z-direction. I think this make it more difficult to be meshed.
Old   March 23, 2012, 05:34
Far
Sijal
In my sanity, the blocking would be exactly same.
Old   March 28, 2012, 02:18
jeevan kumar
jeevankumarb is on a distinguished road
If you can upload your tin and blk file then it would be easy to give some suggestions on your mesh.
jeevankumarb is offline   Reply With Quote
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 08:52
Moving Mesh Velocity Issue: Mesh velocity does not equal displacement Doginal CFX 2 September 8, 2011 12:02
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
