[ICEM] Suggestion on how to mesh this geometry by structered(Fuel Rod)
Like Tree3Likes
Old   March 13, 2012, 17:26
Question Suggestion on how to mesh this geometry by structered(Fuel Rod)
Conqueror
fatihsinan is on a distinguished road
hello everyone, i am new at icem cfd and i have a coolant channel geometry as hexagonal and it included a cylindrical hole,coolant flow around this cylinder,and along this coolant channel there are 6 small solid structure, First of all i start by o grid splitting then i split block around these small solid,i delete all other blocks because there is a 120 degree symetry if i complete one part then i can copy to other part, But i cant properly block around small solids, Can anybody suggest a strategy for blocking? I appreciate all your help in advance, THANKS
fatihsinan is offline   Reply With Quote
Old   March 14, 2012, 08:26
Conqueror
is problem statement not clearly ?
Old   March 14, 2012, 09:14
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
if you could provide tin and blk, then It would be easy to comment/help
fatihsinan likes this.
Far is offline   Reply With Quote
Old   March 14, 2012, 09:36
Conqueror
i uploaded .tin and . blk files thank you for your interesting
Old   March 15, 2012, 14:28
Conqueror
everybody can find solution on forum , is this geometry so hard ? or impossbile
Old   March 24, 2012, 01:19
Far
Sijal
Inner cylinder is solid or Fluid is going through this region as well. See pic
Old   March 24, 2012, 03:54
Conqueror
yes its region is solid ,and other six small pieces [SG1,SG2,SG3,SG4,SG5,SG6] are also solid,
Fluid flow around this solid cylinder as through hexagonal channel.
Old   March 24, 2012, 03:56
Conqueror
fluid enter the channel from bottom of hexagonal channel,and cylinder surface is heated wall,and hexagonal channel side 6 walls are symetry condition
Old   March 24, 2012, 07:28
Far
Sijal
These curves are necessary? Topology can be simplified If we can delete them
Old   March 24, 2012, 09:26
Conqueror
these edges are not real,i draw those while trying block,you can delete
Old   March 27, 2012, 06:26
jeevan kumar
jeevankumarb is on a distinguished road
Please find the blocking attached. Hope it will be useful for you.
Regards
Far and fatihsinan like this.
jeevankumarb is offline   Reply With Quote
Old   March 27, 2012, 06:27
jeevan kumar
Sorry i forgot to mention that i haven't done the bunching properly. You can do the bunching according to your requirement.
Old   March 27, 2012, 07:33
Far
Sijal
good job. Well done
Old   March 27, 2012, 18:06
Conqueror
Far and jeevan kumar thank you very much,
and i wonder about strategy i did same split for blocks but i cant properly associate edge to curves ,what is the key point ?
Old   March 28, 2012, 10:39
Far
Sijal
http://www.4shared.com/rar/pjL8Uzmi/fuelrod.html
I have used combination of top-down and bottom up approaches. Top-down for the main blocking and bottom-up for final touches.
On other side still I have to use the extrude along curve the to finalize the blocking. Then you need to associate the newly created edges and specify edge mesh parameters.
I am trying to record the whole procedure to upload on the youtube.
PS. Could some body illustrate that how to completely block this geometry with only top-down approach.
Old   March 28, 2012, 11:03
Sören
despaired student is on a distinguished road
@fatihsinan: where do the association-problems appear? After what operations/ in which situation?
despaired student is offline   Reply With Quote
Old   March 28, 2012, 15:33
Conqueror
In last blocking there isnt any problem, all process is fine , well done,i wonder only about strategy because i tried same thing before opening this thread
Thanks , Far ,jeevankumarb and despaired student
Old   March 28, 2012, 21:34
Far
Sijal
Did you mean the exactly same strategy by jeevankumarb and later by myself? Since I made use of top-down and bottom up and really want to know if this can be possible fully with top-down approach.
Old   March 29, 2012, 01:13
jeevan kumar
Yes it is possible with top down aproach. But it will take more time then the Bottom up approach. Ultimately you have to decide which is the best approach and which will reduce the time and effort. For this case i think the Bottom up approach is the ideal one.
Old   March 29, 2012, 03:05
Far
Sijal
Right. Could you please comment that my approach is also similar to yours? I used mix of both approaches. Top-bottom for main blocking and bottom-up for three (3 * 2 = 6) small solid pieces.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] Mesh a geometry without stl file eysteinn OpenFOAM Meshing & Mesh Conversion 0 May 5, 2011 10:15
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
