Home > Forums > ANSYS Meshing & Geometry
[ICEM] Interface and peroidic
Old   April 3, 2012, 02:45
Default Interface and peroidic
mohamed khedr emam
m5edr is on a distinguished road
Hi All
I'm stuck with this problem and need help
I will explain briefly
My geometry is 1/3 of wind turbine domain
I had one small domin aorund blade which is rotate and a big domain around the small which is stationary .... this is a typical MRF problem
Between this domains the surface must be interface ( i spent one month for making it interior , finally i discovered it must be interface )
every thing alright include periodic sides until i made (Split mesh => Split Internal Wall) the problems as following :
1- When i do a "check mesh", bad periodic problem result such as (shell has node which has no twin) and Fluent NOT accept the mesh
2-i don't know whether fluent didn't accept the mesh due to periodic problem or due to splitting internal wall
Finally i need to know the difference between interface B.c (which specified in Icem before send mesh to fluent and Mesh interface which made in fluent) ... because if they the same the problem will solved and no need for splitting the wall
I thought in many directions But no solution results
regards
thanks in advance
m5edr is offline   Reply With Quote
Old   April 4, 2012, 06:08
mohamed khedr emam
Any idea
My files are upon request
Thanks in advance
Old   May 21, 2013, 05:26
s.q
s.q is on a distinguished road
Originally Posted by m5edr View Post
Hi All
regards
thanks in advance
hi mohammad
i,m facing a problem such as yours.
i,m simulating a big wind turbine in fluent and i dont know which bc are suitable for this project.
i had set MRF for fluid around turbine and stationary zone for other parts.
after solving whit this parameters my velocity magnitude contours are 0.
would you plz help me????
s.q is offline   Reply With Quote
Old   May 22, 2013, 07:42
Andreas
a.ob is on a distinguished road
Not sure if you managed to solve the problem yet but,
Did you check that the periodicity is set up correctly in ICEM? under Global mesh setup.
Also, for each vertice that exists on a periodic boundary you have to define which vertice it's periodic to.
/Andreas
a.ob is offline   Reply With Quote
Thread Tools
Trackbacks are On
peroidic boundary condition Ramesh.K FLUENT 4 April 25, 2007 06:28
