[ANSYS Meshing] Different settings for multiple faces in Inflation
Old   April 6, 2012, 13:40
Default Different settings for multiple faces in Inflation
killtimm is on a distinguished road
Hi, all, I'm a beginner using ANSYS Meshing.
I have a single 3D geometry of multiple faces.
What is way to set individual parameters in Inflation for different faces, since I want the boundary layers for those faces to have different maximum thickness.
Appreciate so much if you can help me out!
killtimm is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
