Help with connection and enclosure
2 Attachment(s)
Hi all,
I'm trying to create simple enclosure with one plane over the attached model. The problem is that the operation fails with " Error- operation would result in non-manifold bodies context: Geometry Engine, while generating feature enclosure3. " I guess that it comes from the 3 red lines indicates that they are not connected, but I couldn't connect them no matter what I tried... Thanks for your help! |
I am facing same problem. Did you find solution to it?
I tried to use sew operation but in vain. |
share your project...
What was the problem with original files... :o
The bodies at the base of the wings meet at the bottom of the fuselage at an edge. I guess combined they are not really a "valid" solid. You cant subtract or combine something with zero thickness, which i guess is what this connection is treated as. For example, you cant unite the two wing bodies together.
Thats my theory anyway |
Can you please show me the screen shots (design modeller) of the operations you have applied in sequence . Can you please explain the overall procedure ?
Thanks for your help. :) |
Disregard my last post/file.
The main problem is that your fuselage was a surface and the rest are solids. I closed the holes in the front and back with Concept > Surfaces From Edges. Then in your Sew body operation, make sure to select Yes in the "Create solids?" fields. http://i.imgur.com/buc2r6I.png Then its a simple manner of creating the farfield and subtracting the plane. http://i.imgur.com/Q0Kb974.png https://www.dropbox.com/s/gmo0t5lrnv..._plane_v2.agdb |
Transient structural analysis
2 Attachment(s)
Thank you everyone for sharing your precious solutions and helping each other. I am here to ask about my problem in transient structural analysis. When i am importing my geometry for transient structural analysis, it is showing various yellow patches, and when i zoom in enough, it shows red lines. I am not able to do boolean operation due to this issue. can you please help me in this issue. Secondly, i tried the same geometry separatly in fluent and i did not saw any yellow patches and red lines. Boolean was possible by suppressing few bodies. I think, geometry has some issue. Kindly check images, and help me. |
