June 24, 2009, 23:29 |
Steps to create a quater O grid or Y grid
Ben
Rep Power: 16 |
Was wondering if anyone could inform me if I am creating my Y grid correctly as I am getting a non manifold node error when I try to create the boundary layer. For a background to the project/issue have a look at this discussion http://www.cfd-online.com/Forums/ansys-meshing/65005-c-gridding-removing-triangular-blocks.html These errors may be the errors PSYM was referring to at the end of the above thread. Steps used 1. Delete triangular block inside fin (appendage) 2. Create a new block from Create block - From vertices/faces and a select quarter o grid. 3. I then select the 6 vertices in shown in the attachment 4. The Y grid is then created. I continue this for the fwd and aft sections of all appendages and also for blocks through the Fairfield. Could some on please tell me if this is the correct method and or if am missing a step. Is there a way to create y grids without deleting the existing blocks? Any help would be very helpful. Ben |
June 29, 2009, 00:59 |
Ben
Rep Power: 16 |
i got it to work, i needed to extend the y grid into the block below the fin to allow the boundary layer to be generated
June 29, 2009, 13:33 |
Great.
Simon Pereira
Rep Power: 47 |
Right, you need to continue the new topology right out of the model in both directions.
As for another way to do it, yes, you could split you way to success. The process would involve a series of splits and merge blocks, followed by a collapse blocks to pinch the merge all the way out the model. There are pro's and cons to each way, but the way you did it is a little more straight forward and not as easy to mess up. Best regards, Simon |
April 12, 2012, 05:46 |
Some details are also discussed in this thread.
Meshing a Sphere | Ajay | FLUENT | 10 | September 3, 2016 14:18 |
How to create peristicaltic flow with grid deform. | Anthony | Main CFD Forum | 0 | August 30, 2006 03:06 |
2d CGNS grid for use with ensight | zonexo | Main CFD Forum | 0 | May 16, 2006 21:37 |
grid interface | Dhandapani.s | FLUENT | 0 | November 5, 2004 12:29 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 11:18 |
