Home > Forums > ANSYS Meshing & Geometry
[DesignModeler] 2D: thickless elements inside domain
Old   April 14, 2012, 11:17
Default 2D: thickless elements inside domain
thaenan is on a distinguished road
I would like to create a thickness element (a wall) inside a 2D domain in DM. I draw a line, for example, and when I try to create the surface in the domain, it just ignores the presence of this element. As a conseuence, Meshing doesn't recognize it at all.
Would someone help me on this problem, please?
Thanks
thaenan is offline   Reply With Quote
Old   April 14, 2012, 11:55
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Are you trying to model for example flow over a surface ?
If so here is what you should do, let's say your body or "wall" is an airfoil. start by drawing the airfoil. after that go to surfaces>surfaces from edges. you will then have a surface representing the airfoil. Then continue by drawing the edge "the boundary condition", and then create another surface from edge and select your edges make sure you create your second surface as "add frozen" so it would not be merged to the first one. final step is to do a Boolean operation and to subtract the first surface and leave the second one with empty space which represent the body.
I just did a summary of this tutorial here: https://confluence.cornell.edu/displ...oil+-+Geometry
i hope i could help you.
Regards,
New to ICEM CFD, try this document --> http://goo.gl/G2gkE
Ali
diamondx is offline   Reply With Quote
Old   April 14, 2012, 13:12
Hi diamondx,
first of all, thanks for your answer and the tip of the tutorial.
However, what i'm trying to compute is a flow past a surface not closed. I want to simulate an air-air ejector, and I would like to begin with a simple geometry: 2D with thickless elements (shown in the figure , flow comes from the left, in the bottom part). Do you know what I could[IMG][/IMG] do so Meshing understand these lines are in fact walls within the fluid domain? Is it even possible, or must I thicken then?
thanks again
Old   April 14, 2012, 13:13
link to the figure http://imageshack.us/photo/my-images...irairejec.jpg/
Thread Tools
Trackbacks are On
Numerical errors in nested domain with pre-calculated boundary values Arnoldinho OpenFOAM Running, Solving & CFD 3 April 4, 2012 10:31
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
ICEM : elements outside of domain !! Felix CFX 0 February 1, 2008 11:55
Howto Sphere solid as a subdomain inside a domain? jakjak CFX 0 October 24, 2007 23:31
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
