Home > Forums > ANSYS Meshing & Geometry
[GAMBIT] connect two different boundary layers
Old   April 16, 2012, 09:05
Default connect two different boundary layers
Gerardo
GerardX89 is on a distinguished road
Hello everybody,
I am working to my degree project, I have to study the cavitation into a Venturi's tunnel.
I have a problem connecting two boundary layers using Gambit.
The first b. layer was made in this way:
uniform
first row(a)-> 0.001
Growth factor (b/a)-> 1.2
rows 4
internal continuity-> on
wedge corner shape ->on
The second B.layer :
uniform
first row(a)-> 0.008
Growth factor (b/a)-> 1.1
rows 4
the probem is that I have to connect them in a corner and the mesh quality is very very bad there.
Do you know what can I do to improve it?
thanks in advance
GerardX89 is offline   Reply With Quote
Old   April 30, 2012, 04:45
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
do you have pictures?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 2, 2012, 12:57
Gerardo
Max,
Thanks for your interest.
I was able to solve the problem but I had to change completely the mesh because the geometry was too complicated to connect propertly the two b. layer.
But Thanks again
Thread Tools
Trackbacks are On
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
[ICEM] Problem with boundary layers for cylinder in channel nik ANSYS Meshing & Geometry 0 October 27, 2009 07:01
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Boundary layers problem carlos ortiz FLUENT 0 September 20, 2004 20:55
