[DesignModeler] ANSYS 14.5 DesignModeler - Unable to start...
Old   December 2, 2014, 17:27
Default ANSYS 14.5 DesignModeler - Unable to start...
Renegade
martinko814@gmail.com is on a distinguished road
Hello everybody,
i need urgent technical support.
Till last week i was using ansys r12.1, after instalation of ansys 14.5 it crashes after loading of geometrie. APDL is without problems, in full working. Licence is ok.
Instalation of 14.5 without : antivirus, firewall and offline.
I tried to repair it by recommendations to forums.
I used to repair, reinstal windows, installation new graphics drivers, i have all current C ++ Library.
Technical parameters PC:
AMD FX 8350, RAM 16GB
Quadro 600
windows 7 ultimate
THX FOR YOUR KNOWINGS SUPPORTS
without response it writes error:
martinko814@gmail.com is offline   Reply With Quote
Old   December 12, 2014, 03:50
Default had the same problem - does this help?
Christian Stemmer
Christian.Stemmer is on a distinguished road
Knowledge Resources: Solutions
#2037921
Problem Description: Any Mechanical application - Mechanical, Meshing, Design-Modeler & FEModeler will not run after a Red Hat 6.x update: RHSA-2014:1436. Starting Design Modeler from WorkBench simply hangs for two to three minutes and then presents an error: "Unable to start the geometry editor." Mechanical also fails to start. Platform - Redhat6.x or derivatives
Product Family: Installation, Licensing & Systems
Product: ANSYS Mechanical
Version: 15.0
Area: Installation Process
SubArea: Other
Last Updated: Nov 14 2014
Answer:
Resolution:
The fix is a simple rename of a folder. In the path below rename the X11 folder to Old-X11
/ansys_inc/v150/commonfiles/MainWin/linx64/mw/lib-amd64-linux/
Christian.Stemmer is offline   Reply With Quote
Old   May 13, 2015, 10:23
xdonu is on a distinguished road
Thank you very much!!! This was driving me insane.
xdonu is offline   Reply With Quote
Old   October 20, 2015, 23:22
Talles Caio
TallesC is on a distinguished road
I'm like the same problem, but not can not find the file path, so meeting up commonfiles. I use Windows 7 - 64 bit, Ansys version 16.1.
TallesC is offline   Reply With Quote
Old   October 21, 2015, 04:19
That path corresponds to a Linux installation not Windows. So I don't think you'll find it. Your issue is probably related to something different.
unable start geome editor
Ansys 14.5 Problem Import Mesh from ICEM CFD to CFX Smiling Assassin CFX 1 May 9, 2014 02:27
Mesh difference between 14.5 version and 15.0 version in ansys meshing sunxihui ANSYS Meshing & Geometry 0 May 6, 2014 04:22
ansys 14.5 comparability with OS Raj14 CFX 2 February 5, 2013 23:56
How to generate the geometry of Hydrofoil impeller with Ansys designmodeler commonyue Main CFD Forum 0 December 15, 2011 08:43
How can I start the ANSYS 12 workbench in LINUX Ardisia ANSYS 3 September 7, 2010 00:19
