Density of a multi-component mixture
Old   April 23, 2012, 16:23
Default Density of a multi-component mixture
Aditya
dsn2491 is on a distinguished road
I have a mixture of 55% xenon, 35% hydrogen and 15%oxygen by mass fraction in a bubble surrounded by nitrogen medium.
By calculating the density using ideal gas the denisty of bubble should be greater than the density of nitrogen but the bubble turns out to be less denser than the surrounding nitrogen medium.
I have a UDF for specifying mass fractions and when I have only Xe and oxygen the bubble is denser than nitrogen but the moment hydrogen is added (even as little as 0.01 mass fraction), the bubble goes way below the density of surrounding nitrogen.
SETUP: DRIVEN SECTION OF TEH SHOC TUBE WITH NITROGEN AS THE SHOCK TUBE AND A BUBBLE AT THE CENTER.
someone please help.
dsn2491 is offline   Reply With Quote
Density of multi fluid simulation unischlaf CFX 4 September 18, 2011 04:16
Add total mass using sources to multi component fluids mullenc525 CFX 1 February 5, 2011 04:56
Specific heat, density evaluation in mixture eqn CFDtoy Main CFD Forum 1 January 29, 2008 02:08
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
Warning 097- AB Siemens 6 November 15, 2004 04:41
