-   ANSYS (http://www.cfd-online.com/Forums/ansys/)
-   -   Changes to named selections not appearing in CFX? (http://www.cfd-online.com/Forums/ansys/101760-changes-named-selections-not-appearing-cfx.html)
steady-state May 13, 2012 20:28
Can anyone suggest why CFX Pre does not always pick up changes in Named Selections that I make in the ANSYS Mechanical Meshing?
Often I'll add or subtract geometry from a named selection or create a new one, hit update, and refresh CFX Pre, but can't see the new named selection in CFX Pre? Any thoughts as to why this is happening?
rockzh June 27, 2012 20:35
I have the same problem,
do you get the answer?
thank you
Darren Leong July 18, 2012 02:00
Tools>Options>Geometry Import>
Check that Named Selections is enabled (tick left box) and delete the filtering prefixes which usually 'NS' by default.
The setting above applies to new projects created after the change tho.
