-   ANSYS (http://www.cfd-online.com/Forums/ansys/)
-   -   parallel edge (http://www.cfd-online.com/Forums/ansys/102553-parallel-edge.html)
vibhs May 28, 2012 04:37
parallel edge
hi folks,
I have a circle and its vertex on its circumference. Can somebody help me in drawing a line on the same plane in which the circle is, and is parallel to the circle's tangent line at that vertex (if drawn, as right now i dont have that tangent line too).
everdimension June 7, 2012 17:44
You might draw a radius line from the center of the circle and going through the vertex and out of the circle. Then you can draw a perpendicular line to this radius-line within the desired distance from the circle - it would be parallel to the tangent line going through the vertex. To make a line perpendicular to another go to 'constraints' and choose perpendicular tool.
vibhs June 7, 2012 23:51
Hi everdimension...thanks for your reply.....But I cud'nt find 'constraints' in Gambit software.....could you please help me out in that regard...
everdimension June 8, 2012 04:03
I'm sorry, I assumed you were working in Ansys Design Modeler. I do not know gambit...
