Export deformed meshes from Static!!!
Old   June 7, 2012, 05:56
Default Export deformed meshes from Static!!!
kamu123 is on a distinguished road
Hello all,
I want to know how to export the deformed mesh by static structural.
I will import the deformed mesh into FlUENT and simulate.
When i tried to export the mesh from Static Strctural, I could just export before deforming and failed to export the final data.
I studied about system coupling program ansys14.0, but i need some information which i can use on fluent respectively.
Anyone who knows how to export the meshes which were completed deformation into fluent?
Thanks a lot
kamu123 is offline   Reply With Quote
Old   June 7, 2012, 16:44
tmeysam92
tmeysam92 is on a distinguished road
Hi kamu123,
I want to work on FSI problems.
do you have any tutorial about ansys fluent fsi problem?
I really need them.
thanks in advance.
tmeysam92@yahoo.com
tmeysam92 is offline   Reply With Quote
deform, mesh, static structural
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 04:24
fprint problem MASOUD Fluent UDF and Scheme Programming 5 October 30, 2011 16:08
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 05:08
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 00:49
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
