Restarting batch job of system coupling in ANSYS14
Old   June 25, 2012, 08:30
Default Restarting batch job of system coupling in ANSYS14
ST
bbhv is on a distinguished road
I am trying to restart a system coupling job (ansys 14.0) in batch.
My initial run lasts for 10 load steps, which is equal to 1e-05s.
Now, I want to restart from loadstep=10 (the initial run) to loadstep=100, which is equal to t=1e-04s.
I'm following the steps in ansys 14.0 system coupling user guide to create a restart input file (called dsRestart.dat in this case) with the following contents:
/batch
/solu
/gst,on,on
antype,4,rest,10,1,continue
solve
save
finish
/exit
The loadstep of 10, and substep of 1 are cited here.
I put this dsRestart.dat in the results folder of the initial run, and then execute the following command:
/opt/ansys_inc/v140/ansys/bin/ansys140 -p AA_R -b -schost=node1_forexample -scport=12345 -scname=Solution -i dsRestart1.dat -o ANSYSRestart.out
then, straightaway it gives an error: No nodes defined
Any hints?
Thanks
bbhv is offline   Reply With Quote
Remeshing_ ANSYS 14.0_ System Coupling acdesa ANSYS 4 November 2, 2016 09:12
FLUENT Batch job Saravanan FLUENT 11 May 14, 2014 16:47
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Running Job in Batch mode (EFD) Nick Sessions FloEFD, FloWorks & FloTHERM 0 April 16, 2008 16:44
Passive cooling system for batch reactor Darek Main CFD Forum 0 September 30, 2003 05:06
