Object reference not set to instance of an object
Old   September 30, 2016, 02:20
Default Object reference not set to instance of an object
zeeshe
muhammadzeeshan92 is on a distinguished road
Dear All
I have installed ANSYS 15.0 on my Lab top. When I run hydrodynamic module on
workbench, the following text appears upon editing Model: Object reference not set to instance of an object.
Kindly do guide me how I can settle with this problem.
Waiting for prompt response.
Muhammad Zeeshan
muhammadzeeshan92 is offline   Reply With Quote
Old   April 16, 2019, 11:15
dhaval is on a distinguished road
Were you able to resolve this issue? I am running into same problem and not finding much help online. Let me know if you have some advice. Thanks.
dhaval is offline   Reply With Quote
Old   September 16, 2019, 08:00
Default Same issue with ANSYS Meshing
Robin
ro_bb is on a distinguished road
I get the same error, when I create a Fluent or Meshing workflow and try to open a geometry I created in SpaceClam in ANSYS Meshing.
The only way it worked for me was by starting Work Bench with administrator rights. This is super annoying though, since I loose access to my User's drive
UPDATE:
After some conversation with the customer support, disabling the "Preload Meshing (beta)" option in Tools - Preferences of Workbench fixed the problem for me
ro_bb is offline   Reply With Quote
Old   October 10, 2021, 12:57
Sar
Subodha
Sar is on a distinguished road
Originally Posted by muhammadzeeshan92 View Post
Dear All
Muhammad Zeeshan
Could you resolve this problem ? If yes can you kindly tell me the way
Sar is offline   Reply With Quote
error message cuteapathy CFX 14 March 20, 2012 06:45
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile val46 OpenFOAM Installation 4 August 27, 2010 03:43
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
compile error about FJMPI chiven OpenFOAM Installation 11 March 31, 2010 06:27
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
