Fluent-Structural help
Old   July 6, 2012, 21:10
Default Fluent-Structural help
zakir
zakir hussain is on a distinguished road
Hi
I want to do a simulation on 1-way FSI from fluent to Mechanical.I think I need use the FSI mapping(-> surface map) function.But then I have to input a Ansys(APDL) file(.cdb file).what confused me is where is this .cdb file from.I already have finished a steady simulation and have the result(.data file) file.What I need to read into Mechanical solver is only the pressure profiles.
Thank you very much!
zakir
zakir hussain is offline   Reply With Quote
Old   July 27, 2012, 16:31
Default Use custome system FSI in ansys 13
nauman hashmi
nauman55 is on a distinguished road
sir you can do it by using custom system tab in ansys 13 from where you can select an FSI by using fluent or cfx. in this case you wont be needing an fsi mapping in fluent. just carry out your simulation and then import pressure load in ansys static structural module.
hope it resolves your query
i am available at naumaneshanhashmi@gmail.com for further assistance
nauman55 is offline   Reply With Quote
fluent-structural
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 02:57
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
