Error messages
I am new to Fluent software. I am using Ansys 13.
When I am importing a mesh to Fluent, it is showing the following message. 785292 nodes, binary. 34721 nodes, binary. 9135883 mixed interior faces, zone 1, binary. 6737 triangular wall faces, zone 5, binary. 563 mixed velocity-inlet faces, zone 6, binary. 515 mixed pressure-outlet faces, zone 7, binary. 41460 mixed symmetry faces, zone 8, binary. 17763 triangular wall faces, zone 9, binary. 4554076 mixed cells, zone 2, binary. Building... mesh Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc face-dr1, size 109630596, t 1, myid 1000000. Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: #f Preparing mesh for display... Done. Preparing mesh for display... Done. Reading Settings file C:\Users\amarendernag\Documents\ansysfiles\car_fil es\dp0\FFF\Fluent\FFF.set... Error: SET-CDR!: invalid argument [1]: wrong type [not a pair] Error Object: #f Setting Post Processing and Surfaces information ... Error: lvectorlength: wta(1) Error Object: () Please help me to overcome this problem. |
Hi, I'm facing the same annoying problem.
Did you find a solution? |
| All times are GMT -4. The time now is 07:53. |
