Any suggestion of improvement? (Longer re-circulation length in periodic hill flow) |
August 21, 2012, 14:31 |
Daniel WEI (老魏)
Rep Power: 21 |
I ran several detailed simulation using k-omega sst model, in low re mode, with low re mesh for channel flow, and the results are perfect.
And then I started to try periodic hill as it is in ercoftac database. The results are not bad, thought the recirculation length is longer than reference. I've done grid convergence, and also double checked the other numerical schemes.. So my question is, What is your experience with sst model in predicting the recirculation length? Is this the best that SST model can do for now? Or does Dr. Menter has some important and better improvement of his model these years? Many thanks in advance,
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
Flow between parrall plates entry length formual? | S. S. Mudathir | Main CFD Forum | 4 | June 24, 2015 08:24 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
