Wind turbine
Old   September 8, 2012, 03:24
Unhappy Wind turbine
James Hetfield is on a distinguished road
Hello
I want to generate a mesh around the rotor+tower of a windturbine
so I need a rotating mesh inside a stationary one
can anyone help me with it? is it good to use ICEM or I should use Ansys Meshing?
Id appreciate any kind of information
thanks
James Hetfield is offline   Reply With Quote
Old   September 11, 2012, 06:53
Sascha
SaschaGH is on a distinguished road
Are you using Ansys Turbo Components ? Meshing for Turbo machinery is made easy with TurboGrid. If you don't have the licences for TurboGrid, you might wanna ask again in the Subforum Ansys Meshing & Geometry for advice on how to mesh according to your research interest. Then you might wanna explain a little more, sketch your geometry and state the parameters of interest.
Greetings
SaschaGH is offline   Reply With Quote
Old   September 11, 2012, 19:39
hello
thanks for the reply
I thought TurboGrid is for compressors, jets, ... not for windturbines
am I wrong?
in case its possible to generate a mesh around windtubines with TurboGrid, can you give me tutorials if u have any?
thanks a lot
Greetings
Old   September 12, 2012, 09:10
Sascha
Hello James,
I haven't used turbo grid or bladegen for wind turbines, but I guess it should be no problem. Check this out. I don't have any tutorials for your demands, but I might give you some tips once you sketch your geometry and explain a bit more what your goals are.
Greetings
Ducted wind turbine (BC for the shroud) Pepita CFX 4 June 29, 2013 07:09
Wind turbine simulation problem sanchovg2 STAR-CCM+ 12 March 5, 2013 04:18
FSI - Wind Turbine AUN CFX 13 August 29, 2012 16:44
Wind turbine simulation Saturn FLUENT 1 June 16, 2006 02:12
Wind turbine simulation Saturn Main CFD Forum 1 June 12, 2006 03:57
