Home > Forums > Software User Forums > ANSYS
Time periodic heating
Old   September 3, 2012, 05:11
Default Time periodic heating
mfuchs is on a distinguished road
I´m trying to modell the following 2d-system. There is a glas plate with a thickness of about 2mm and about 4 cm length. It is covered with a thin metall film (~ 10 microns). The film is periodocally heated from the upper side on one end of the system by a given heat current with an frequency of about 100 mHz. The heat sink is placed on the opposite end of the glas plate and is just a wall with constant temperature (293K)
The modelling and meshing is fine but it turns out that it takes very long to calculate and evaluate the experiment. The problem is that I have to use rather small timesteps (1/1000 sec) because of the evaluation that follows after the simulation. So here is the question:
Is it possible to get a time periodic solution? I have found something similar for ansys fluent:
https://www.sharcnet.ca/Software/Flu...ug/node392.htm
I do not need the start up phase but the start up phase lasts some hundred seconds. When I load the results in Ansys post it takes hours to get graphs.
thanks for your help
mfuchs
mfuchs is offline   Reply With Quote
Old   September 5, 2012, 10:13
Sascha
SaschaGH is on a distinguished road
Hey mfuchs,
if I understand you correctly all you need to do is manually delete the unnecessary (.trn) of the start up process (check with your timestepsize) or a priori define in cfx-pre when the output of your transient results should begin, which can be done in the output control tab. With the reduced number of timesteps you can then create a transient chart in post to see whether your problem has time periodic character.
If your startup phase lasts some "hundred" seconds but you use 1/1000 sec, how many hours/days does it take to calculate the problem ? Ever thought of using a bigger timestep for the beginning to obtain transient stabilization faster and then switch to the desired timestep for evaluation ?
Greetings
SaschaGH is offline   Reply With Quote
Old   September 11, 2012, 05:00
ok this works fine. Thank you.
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
Residence Time Distribution with Periodic Boundary Conditions sanjose FLUENT 1 September 7, 2016 04:13
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 07:56
Plot heating and cooling rate (dT/dt) vs time Frederic FLUENT 0 February 6, 2005 04:00
