Wind turbine
Hello
I want to generate a mesh around the rotor+tower of a windturbine so I need a rotating mesh inside a stationary one can anyone help me with it? is it good to use ICEM or I should use Ansys Meshing? Id appreciate any kind of information thanks |
Are you using Ansys Turbo Components ? Meshing for Turbo machinery is made easy with TurboGrid. If you don't have the licences for TurboGrid, you might wanna ask again in the Subforum Ansys Meshing & Geometry for advice on how to mesh according to your research interest. Then you might wanna explain a little more, sketch your geometry and state the parameters of interest.
Greetings |
hello
thanks for the reply I thought TurboGrid is for compressors, jets, ... not for windturbines am I wrong? in case its possible to generate a mesh around windtubines with TurboGrid, can you give me tutorials if u have any? thanks a lot Quote:
Hello James,
I haven't used turbo grid or bladegen for wind turbines, but I guess it should be no problem. Check this out. I don't have any tutorials for your demands, but I might give you some tips once you sketch your geometry and explain a bit more what your goals are. Greetings |
| All times are GMT -4. The time now is 08:04. |
