ansys 13 license
Hello genius!!!
I have also a mini problem.. My pc - status is: ANSYS, Inc. License Manager status: Licensing Interconnect: not running Licensing Interconnect Monitor: not running FLEXlm: not running I've found that: Failed to start the FLEXlm license manager. Please check the FLEXlm log file C:\Program Files\ANSYS Inc\Shared Files\Licensing\license.log for more information (errno = 2). Could not start FLEXlm server. Please check the FLEXlm log file. Exiting. I check the license.log : 1: Unable to kill lmgrd.exe. Please kill this manually by opening the Task manager and Killing the lmgrd.exe which are still running I know that lmgrd.exe. is not visible.. 2: Not a valid server hostname, exiting. Thank you for your patient.. K.P |
The problem was with my internet connection..
Maybe a router problem or a problem with blocked port from my internet supply company.. I hope I help someone with same problem.. |
hi everybody
i have same problem with my license manager what can i do? |
Hello hamid341d, I would check it first with my internet supply company.. Ask them, especially if you use vpn in order to connect with License server!! You can also check if your License is valid... |
Hello there,
I also have a problem with licensing ANSYS 13. When I installed everything and run Workbench I get a "Missing component template" error. That means I do not have any access to "mesh, fluent, cfx or geometry". I heard that this is a language issue but I could not fix it. Is there anyone who could give me a clue? Thanks in advice. |
