Home > Forums > ANSYS
[icem]
Old   October 18, 2012, 11:03
Default [icem]
helios is on a distinguished road
Hi at all, i try to find out an ICEM programming manual to modify its own macro.where or how can i found it? thanks
helios is offline   Reply With Quote
Old   October 27, 2012, 08:55
Stuart Buckingham
stuart23 will become famous soon enough
Helios,
The Programming manual gives you all the ICEM related commands to create/modify geometry, mesh and blocking. You can also use normal tcl/tk commands for things like variables and maths functions.
Hope this helps,
Stu
http://bc247.wordpress.com
stuart23 is offline   Reply With Quote
Old   October 29, 2012, 07:46
thanks for your help Stu. i appreciate that too much.
Helios
Old   October 29, 2012, 09:08
Stuart Buckingham
No problem.
Do you have a specific task you are trying to do? Post again if you need a hand.
Stu
Old   October 30, 2012, 07:56
i have to do a complete campaign of analysis measuring lift, drag and so on between [-5,+13] angle of attack's degrees for 3 thin airfoils. i have registered macro which create the meshes but i have to write the recoursive routine to make what i said.Sorry for my worst english but i hope i was fair.
Thanks again
Helios
Thread Tools
Trackbacks are On
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
[ICEM] Octree surface mesh issue siw ANSYS Meshing & Geometry 6 February 13, 2011 13:46
[ICEM] Meshing Error with a Solidworks Geometry Fractal ANSYS Meshing & Geometry 0 September 30, 2010 10:20
[ICEM] Forcing surface and curve to match sherifkadry ANSYS Meshing & Geometry 0 August 27, 2010 00:28
[ICEM] Trying out with Hexa for a wing siw ANSYS Meshing & Geometry 0 August 26, 2010 10:13
