November 17, 2012, 11:43 |
Errors Upon Opening Fluent
Rep Power: 14 |
I have a geometry and mesh that I created in Ansys (version 13) DesignModeler and Mesher. I successfully ran simulations in FLUENT. Now I am using Ansys 14. Whenever I try to start up FLUENT (the setup tab in workbench), I get odd errors. When importing the mesh, the console says "Error: %%create-sliding-interface: wta(sb1-id)". It then shows a dialog box saying "get-thread: invalid thread id (integer) or name (symbol)" If I click "check" after this, it says that "Fluent received fatal signal (ACCESS_VIOLATION)" I have redone the model and mesh in Ansys 14 but still the same errors occur. I do not have sliding interfaces. I do not even know what these are. I have read from other posts that this is fairly common in Ansys 14, where people had these issues after not having any in Ansys 13. Yet no good solutions were mentioned. I would appreciate it if someone could point me in the right direction. Because my model and mesh worked in 13, I think it must be some demons in Ansys itself, and not my model. Thank you for your time. |
ansys 14, errors, fluent, invalid thread, sliding interface |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
help for opening gambit file n Fluent..... | rizwan | FLUENT | 1 | March 22, 2009 22:41 |
Errors while eporting mesh to Fluent | Vidya Raja | FLUENT | 5 | March 2, 2006 00:17 |
