ANSYS APDL in Ubuntu 12.04 chinese characters
H i successfully installed ansys in ubuntu 12.04 64bit an every semms to work fine exept wen i run the ansys APDL from " /ansys_inc/v140/ansys/bin/launcher140" the menus languages are in chinese or japanese :)
any idea? |
I have the same problem with chinese/ japanese menus with Ubuntu 13.4 and Ansys 14.5.7 APDL.
The Ansys installation guide refers in the troubleshooting section to this bug: If Red Hat was installed in all languages, I should reinstall Red Hat again in english only. Further, the state that this bug won't be fixed. As far as I remember I did install Ubuntu in english only. Does anyone knows how to transfer this troubleshoot description from Red Hat to Ubuntu or has a workaround do fix this? |
Possible Solution
I just had the same problem on a Linux Mint Maya (based on Ubuntu 12.04) system.
I do not know exactly what package fixed it but I installed the following and the pop up Windows were not Chinese anymore: sudo apt-get install xfonts-75dpi xfonts-100dpi xterm ttf-mscorefonts-installer You do need to restart your system (it might be enough to restart the X server)! You could try the xfonts-75dpi and xfonts-100dpi packages first and verify if this works (restart!) or if you need the Microsoft core fonts. Best regards |
firesoul, thanks for your reply!
Installing the packages and a restart helped wit the problem: sudo apt-get install xfonts-75dpi xfonts-100dpi Best regards |
