January 16, 2013, 11:24 |
Meshing problem?
Rep Power: 13 |
I'm a newbie with meshing. But with the help of some tutorials and this forum, I was able to create my first mesh. Unfortunately, some errors occured while doing the simulation with CFX-Solver Manager (see image01). I hope someone can tell me, if the problem was the mesh or perhaps adjustments in CFX-Pre.. |
January 16, 2013, 12:04 |
Rep Power: 13 |
Since it is my first mesh, I don't know at all which values should be entered
To get an impression of the size, the dimensions of the test chamber are: Length: 14 458 mm Diameter: 3032 mm So I tried it this way: - Register Mesh - Surface Mesh Setup - Surfaces: I selected all surfaces, entered Maximum size: 150, Height: 150, Min size limit: 20 and all others: 0 - Apply. - Register Mesh - Compute Mesh - Volume Mesh - Compute. Volume Mesh is Tetra/Mixed and Mesh Method is Robust (Octree) - Check Mesh and ignoring multiple edges and single edges since they shouldn't be a problem. Delete unconnected vertices. - Then, I wanted to add 10 layers of prism: - Register Mesh - Compute Mesh - Prism Mesh. - There I selected the parts for the prism layers, entered there num layers =10 and clicked "ok". - Then I clicked surface mesh up, chose the surfaces of the tube and the small nozzle, changed Maximum size: 50, Height: 5, Min size limit: 10, Height Ratio: 1.5 and applied. - Register Mesh - Compute Mesh - Volume Mesh. I enabled create prism layers and computed. - Check Mesh and again ignoring multiple edges and single edges. I hope someone knows some better values to start than mine! Or another meshing strategy... |
January 16, 2013, 12:56 |
Rep Power: 13 |
@admins: Sorry, I posted in the wrong forum, please delete this thread
Display Modes | |
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 19, 2023 00:49 |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 08:21 |
Strange ANSYS Meshing 13.0 Problem | brunob | ANSYS Meshing & Geometry | 3 | June 21, 2011 21:03 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 21, 2006 00:31 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 10:22 |
