-   ANSYS (http://www.cfd-online.com/Forums/ansys/)
-   -   Ansys on Windows 8 (http://www.cfd-online.com/Forums/ansys/112136-ansys-windows-8-a.html)
JaC January 22, 2013 16:28
Ansys on Windows 8
does anybody know if you can install and use ansys 14 or ansys 13 on windows 8 64bit?
Thank you
Jakub B.
diamondx January 23, 2013 20:30
yes you can i'm running 32 bit version tough
HMN February 11, 2013 09:54
I tested Ansys 14 and 14.5 in Windows 8 x64 without problems. :)
For me it works better in W8. This OS is very fast!
eddyready May 26, 2013 13:19
Yeah works great on win 8 But sometimes BSOD error ! :(
Gold June 6, 2013 22:13
Udf
i installed Ansys 14.5 on windows 8 but i m getting error loading UDF.
i had the same problem on compiling with windows 7 at the time i installed SDK and visual studio 10 and i used Ansys with SDK command shell and that worked but i can use the same approach because SDK for windows 8 does not have the same command shell.
Any suggestion?
Thanks
Gold June 7, 2013 15:12
Any suggestion?
Thanks
eddyready June 9, 2013 05:57
reply
Any suggestion?
Thanks
Would You plz send me the error ? What does it say?
And,.. By UDF, You mean UDF in Fluent ? or sth else ?
Gold June 9, 2013 08:43
Thanks for reply,
it is UDF in Fluent
when i try to compile UDF after pressing built, it says:
> Copied c:\users\iman\desktop/C:\Users\Iman\Desktop\UDF02sec.c to libudf\src
udf_names.c file in 3ddp is upto date.
(system "copy "C:\PROGRA~1\ANSYSI~1\v145\fluent"\fluent14.5.0\sr c\makefile_nt.udf "libudf\win64\3ddp\makefile" ")
1 file(s) copied.
(chdir "libudf")()
(chdir "win64\3ddp")()
'nmake' is not recognized as an internal or external command,
operable program or batch file.
Done.
and after loading i constantly get this error:
Opening library "c:\users\iman\desktop\libudf"...
Error: The UDF library you are trying to load (libudf) is not compiled for 3ddp on the current platform (win64).
The system cannot find the file specified.
c:\users\iman\desktop\libudf\win64\3ddp\libudf.dll
Error Object: #f
I've installed VS 2012 on my machine since VS 2010 is not compatible with windows 8.
Thanks
drkaero August 21, 2013 02:21
hi i am trying to install ansys 14.5 in win 8 x 64 but got some error. can anyone plz send me help file.
drkaero August 21, 2013 02:25
can u plz send helpfile on 'drkaero@gmail.com'
amojodi April 26, 2014 07:40
Dear
I am using ANSYS Fluent 15.0 and Win 8.1(x64). I cannot compile a udf in Fluent and it give the following error
I would greatly appreciate if you help me to solve this boring problem.
amojodi April 26, 2014 07:49
1 Attachment(s)
I have attached my UDF, any help would be greatly appreciated.
