Trouble importing frame from PRO-E to Workbench
Like Tree3Likes
  • 1 Post By HMN
  • 1 Post By irishguy
  • 1 Post By HMN
Old   February 10, 2013, 17:51
Default Trouble importing frame from PRO-E to Workbench
Jordan
irishguy is on a distinguished road
Hello, I made this frame for a small tractor as a part file in PRO-Engineer and then saved it as a .igs file (solids check box checked) to be imported into ANSYS Workbench. Upon bringing in the frame I encountered some problematic geometry.
Pictured here:
I was able to successfully mesh it by using the face sizing command and enlarging the element size for the problematic geometry part. (See how that part has larger mesh gaps)
Pictured here:
Upon further inspection, when I hid the right face, it appears to be hollow since the outside face is hidden, but now you can see a gap into the next face? Shouldn't the entire face be hidden since this is supposed to be a solid piece of metal?
Before:
After:
It's looking like every support structure has two faces with a gap in between them when they are supposed to be a solid.
I'm getting some pretty bad results in my opinion and I'm thinking this might be the problem. Any help would be greatly appreciated.
irishguy is offline   Reply With Quote
Old   February 11, 2013, 08:51
HMN
HMN is on a distinguished road
Ufff, i cannot help you, but I know this problem. And it was exactly when exporting from ProEngineer. The parts were defined as volumes, anyway that problem with the inconsistency.
I tried to export it to spaceclaim to try to simplifly the geometry but there was no way.
I hope that somebody know why this happen.
irishguy likes this.
HMN is offline   Reply With Quote
Old   February 11, 2013, 10:58
Jordan
Ok, thanks. I tried exporting from PRO-E as a surface feature, solid feature, and even wireframe feature. They all returned the same looking structure.
Oh and I got the end structural component to mesh by redrawing some extrusions in PRO-E so that is no longer a problem.
HMN likes this.
Old   February 12, 2013, 05:53
HMN
Ansys DM doesn't like solid defined as surfaces ord wireframes. You have to activate only "solid" option. But it still doesn't work for me like that.
Curiosly that only happens with complex bodies. If the body is relative simple, that problems doesn't take place, so I finally decided to open the PROE files with SPACECLAIM and "analyse" it (there's an option to see if there's problems). This program detected some incosistencies, that I don't know why PROE lets. With SC I detected and simplified the problematic areas or removed them.
The best comes when you use the option Prepare>Ansys from SC. It sends the geometry to ansys directly and it works without problems.
I know that that's a patch, and the problem should be solved directly in PROE but I didn't find a way yet!
ansys, import geometry, mesh, proe, workbench
importing mesh from Gambit and other software to ansys workbench mortazavi CFX 12 May 30, 2012 07:38
Pro/Cons of Importing an IGES vs Step file into Workbench jonny_b ANSYS Meshing & Geometry 2 August 3, 2011 11:49
Importing AutoCad Lt dwg file into Workbench A_Perse ANSYS Meshing & Geometry 5 March 10, 2010 14:15
Prosurf to Proam problems, help please William Wallace Siemens 11 February 3, 2006 17:00
Importing geometry from Pro E to ICEM CFD V5.1 sac CFX 2 January 16, 2006 08:38
