Drafting effect on vehicles
Old   March 10, 2013, 08:43
Thumbs up Drafting effect on vehicles
Atul Agrawal
atul2512 is on a distinguished road
Hello everyone,
I am working under a project "Drafting effect on racing cars".Though everything is done I am under some trouble here.
As in here,drafting,I have two car model with a particular distance between each other and I have to analyse the effect of wake of the front car on the car behind it.
I have to keep changing distance betwwen them,like I have to calculat drag coefficient when the car is 0.1m,0.5m,1.0m,1.5m ...and analyse them in one graph.
So Do I have to change the geometry again and agai and then mesh it again and again.There should be som simple solution.
Help.Any link or tutorial will also do
Thanks.Do reply if you can help.
atul2512 is offline   Reply With Quote
changing geomerty, drag coefficients, fluent 13, transient parameter, transient plots
Can Flow-3D solve the Joule-Thomson effect? seasoul FLOW-3D 8 December 21, 2011 00:01
Coanda Effect to produce lift. Austin Main CFD Forum 4 May 23, 2011 07:51
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
VOF and strong surface tension effect phsieh2005 Main CFD Forum 1 August 30, 2005 06:56
Iclude particle diameter effect in wall? yueroo FLUENT 0 April 14, 2001 03:56
