March 30, 2013, 10:57 |
Return with error code 1
Darázs Bence
Rep Power: 13 |
Hi Everyone,
I have a problem concerning error code 1 and don't know what to do. I would like to continue an SST run with and SSG so when I define my new run I select the . def file of the SSG setup and then check the box that says initial values and there I select the SST run's .res file. I tried double precision too, but it would't work. Seperatly, the SSG and the SST setup ran without any problem, I used the same mesh and boundary conditions, and only changed the turbulence model. Thanks everyone in advance. |
error code 1, ssg, sst |
[PyFoam] Why no non-zero return codes? | Horus | OpenFOAM Community Contributions | 3 | May 8, 2012 10:25 |
return in udf | wlt_1985 | FLUENT | 5 | September 21, 2011 04:35 |
Error in CFX Solver | Leuchte | CFX | 5 | November 6, 2010 06:12 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
