WorkBench 14.5 start error [openSUSE 11.4]. Mono libs not found? |
April 15, 2013, 05:57 |
WorkBench 14.5 start error [openSUSE 11.4]. Mono libs problem?
Dmitry
Ansys Workbench 14.5. OpenSuse 11.4.
./runwb2 gives: Code:
Unhandled exception caught : System.DllNotFoundException: Ans.QT.dll at (wrapper managed-to-native) Ansys.UI.Toolkit.QTC.Application:new_ans_qt_Application () at Ansys.UI.Toolkit.QT.Application..ctor () [0x00000] in <filename unknown>:0 at Ansys.UI.Toolkit.QT.UIFactory.newApplication () [0x00000] in <filename unknown>:0 at Ansys.UI.Toolkit.UIFactory.newApplication () [0x00000] in <filename unknown>:0 at Ansys.UI.Toolkit.Application.InstantiateIApplication () [0x00000] in <filename unknown>:0 at Ansys.UI.Toolkit.Application..cctor () [0x00000] in <filename unknown>:0 --- System.TypeInitializationException: An exception was thrown by the type initializer for Ansys.UI.Toolkit.Application at Ansys.UI.UIManager..ctor () [0x00000] in <filename unknown>:0 at Ansys.UI.UIManager.get_Instance () [0x00000] in <filename unknown>:0 at Ans.Program.Runtime.InitializeSplashScreen () [0x00000] in <filename unknown>:0 at Ans.Program.Runtime.Initialize (Ans.Program.RuntimeSettings settings) [0x00000] in <filename unknown>:0 at Ans.Program.Executable.Run (Ans.Program.CommandLineParse parser) [0x00000] in <filename unknown>:0 at Ans.Program.Executable.Main (System.String[] args) [0x00000] in <filename unknown>:0 Code:
Mono: gc took 36 usecs Mono: Unloading image /usr/ansys_inc/v145/Framework/bin/Linux64/runwb2 [0x935c90]. Mono: Assembly Loader probing location: '/usr/lib/mono/2.0/mscorlib.dll'. Mono: Image addref mscorlib[0x936ba0] -> /usr/lib/mono/2.0/mscorlib.dll[0x935cf0]: 2 Mono: AOT failed to load AOT module /usr/lib/mono/2.0/mscorlib.dll.so: /usr/lib/mono/2.0/mscorlib.dll.so Code:
Mono: gc took 50 usecs Mono: Unloading image /usr/ansys_inc/v145/Framework/bin/Linux64/runwb2 [0x927b20]. Mono: Assembly Loader probing location: '/usr/lib/mono/2.0/mscorlib.dll'. Mono: Image addref mscorlib 0x928930 -> /usr/lib/mono/2.0/mscorlib.dll 0x927b80: 2 Mono: Assembly Loader probing location: '/usr/lib/mono/2.0/mscorlib.dll'. Mono: AOT loaded AOT Module for /usr/lib/mono/2.0/mscorlib.dll. Mono: Assembly Loader loaded assembly from location: '/usr/lib/mono/2.0/mscorlib.dll'. Mono: Config attempting to parse: '/usr/lib/mono/2.0/mscorlib.dll.config'. Mono: Config attempting to parse: '/etc/mono/assemblies/mscorlib/mscorlib.config'. Mono: AOT FOUND AOT compiled code for System.OutOfMemoryException:.ctor (string) 0x7fbed617f8e0 - 0x7fbed617f910 0x7fbed6395b3a Mono: AOT FOUND AOT compiled code for System.NullReferenceException:.ctor (string) 0x7fbed6179060 - 0x7fbed6179090 0x7fbed63958e5 Mono: AOT FOUND AOT compiled code for System.StackOverflowException:.ctor (string) 0x7fbed6183a40 - 0x7fbed6183a60 0x7fbed6395d11 Mono: Assembly mscorlib 0x928930 added to domain runwb2, ref_count=1 Mono: Config attempting to parse: '/etc/mono/config'. Mono: Config attempting to parse: '/home/di/.mono/config'. Mono: Assembly Loader probing location: './runwb2'. Mono: Unloading image /usr/ansys_inc/v145/Framework/bin/Linux64/runwb2 [0x98c3e0]. Cannot open assembly './runwb2': File does not contain a valid CIL image. Mono: gc took 51 usecs Mono: AOT FOUND AOT compiled code for System.Runtime.Remoting.Contexts.Context:Finalize () 0x7fbed6253e00 - 0x7fbed6253e30 0x7fbed639cfa2 Mono: AOT FOUND AOT compiled code for System.Threading.Thread:.cctor () 0x7fbed6313da0 - 0x7fbed6313de0 0x7fbed63a30c7 Mono: AOT FOUND AOT compiled code for System.Runtime.ConstrainedExecution.CriticalFinalizerObject:Finalize () 0x7fbed6239880 - 0x7fbed62398b0 0x7fbed639bd9f Mono: AOT FOUND AOT compiled code for System.Threading.InternalThread:Finalize () 0x7fbed6313b60 - 0x7fbed6313ba0 0x7fbed63a30b1 Mono: AOT NOT FOUND: System.Threading.InternalThread:Thread_free_internal (intptr). Mono: Unloading domain runwb2 0x7fbed8becd48, assembly mscorlib 0x928930, refcount=1 Mono: Unloading assembly mscorlib [0x928930]. Mono: Unloading image /usr/lib/mono/2.0/mscorlib.dll [0x927b80]. Last edited by dr-kart; April 15, 2013 at 07:45. |
May 15, 2013, 12:58 |
Same problem here
Shawn Fotovati
I am getting the same error. Were you able to fix it?
Thanks, Shawn |
February 4, 2021, 10:56 |
same error
Rep Power: 7 |
I am getting the same error too.
February 9, 2021, 17:02 |
Rep Power: 7 |
ANSYS is not supported by non-enterprise linux distributions. Do not try to install it on normal desktop distributions, it gives many errors.
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 21:45 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
