Nanotube FE modeling - resultant value much lower than expected
Old   May 10, 2013, 01:27
Question Nanotube FE modeling - resultant value much lower than expected
siddharth
sbk299 is on a distinguished road
I am trying to perform FEM of CNTs using ansys. I have come across several papers regarding this and have followed the instructions. However, the resultant value of the young's modulus that I am getting is much lower than expected ( ~400GPa instead of ~1TPa) I first made the structure using keypoints and lines. Then i defined the elements (Beam188) and its properties (elastic modulus and poisson's ratio). each element corresponds to a single carbon-carbon bond. i also defined the crossectional properties for the elements. Then i meshed the structure and constrained all DOFs at the bottom and applied a force at the top.
Is there something wrong with the procedure being followed?
also, I am using beam188 instead of beam4 (which is used in the papers) as ansys 14 doesnt support beam4. Can this be the reason for the erronious results?
sbk299 is offline   Reply With Quote
nano
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
wmake compiling Problem with OF1.5 openTom OpenFOAM Installation 4 May 3, 2009 14:44
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
