May 14, 2013, 15:45 |
Assign the region to be filled with water
sheikh
Hey guys,
I am modelling a gas water heater in ansys. the problem i am facing is that i am unable to assign my water region to be initially been filled with water so that when my hot flue gases flow through the vent it heats the water. i can only assign mass flow rate to water inlet rather than assign the water cell zone being filled with water. Kindly please help |
May 15, 2013, 08:21 |
Philipp
Rep Power: 26 |
At "Solution Initialization" after initializing click on the "Patch..." button. Here you can set the volume fraction of the water phase to "1" in the relevant zones.
The skeleton ran out of shampoo in the shower. |
May 15, 2013, 08:29 |
sheikh
i tried but the only variable that comes are pressure, x velocity , y velocity and temperature. what must i do?
May 15, 2013, 08:33 |
sheikh
the option of volume of fraction comes when i use multiphase but my model is not a multiphase problem instead 2 fluids separated by a wall
Philipp
Rep Power: 26 |
Firstly select the relevant phase in the small drop-down-menu on the left. It is set to "mixture" by default, but of course you can not set the volume fraction of the mixture.
May 15, 2013, 08:34 |
Philipp
Rep Power: 26 |
Ahh ok, you don't have a multiphase problem, but two different cell zones with different fluids?
May 15, 2013, 08:36 |
sheikh
yeah that is right. one of the cell zone which is water is filled at start. the second zone is of flue gases which heats the water. how do i set my water cell zone as filled with water at initial stage
May 15, 2013, 08:42 |
Philipp
Rep Power: 26 |
I never did that but under "Cell Zone Conditions" -> "Edit" you chose the material of each zone. Isn't that sufficient?
May 15, 2013, 08:44 |
sheikh
that assigns the zone with a particular fluid but it doesn't fill it with one..just provide the zone with those fluid properties.
May 15, 2013, 08:47 |
Philipp
Rep Power: 26 |
But a cell zone with just one fluid is always completely filled with just that fluid.
Boundary conditions for two connected fluid region. | hut | OpenFOAM Running, Solving & CFD | 3 | June 20, 2019 16:45 |
help!!! fluid machanics in water pool | wanglzhy | Main CFD Forum | 0 | February 28, 2012 02:29 |
Simulating Water Splash Using a Particle System | Zi-Wei Chiou | Main CFD Forum | 0 | March 4, 2002 06:33 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
