Workbench - DesignModeler Interaction
hey folks,
i've got a general question concerning the interaction between the workbench and the design modeler. let's say, i just want to create a mesh for a structural analysis and the component has a geometry part and a meshing part. as geometry i use a step file, which i manipulate within design modeler, for example by using boolean operations or the thin/surface command. the imported geometry will be part of an optimization, so it will change slightly from one case to another, however, the applied design modeler operations will be the same for each imported geometry. now, my question is as follows: how do i manage to have the specified modifications applied to the new, slightly different geometry without opening design modeler and tedious jscripting? maybe, some of you have an idea :) thank you |
afaik there need to be a consistent "parametric" setup... so.. you have to be careful on how to apply the "changes".
Some suggestions:
