Airfoil creation in Workbench using its coordinates
Old   August 10, 2013, 03:02
Default Airfoil creation in Workbench using its coordinates
shikha
SHIKHA BHUYAN is on a distinguished road
Hello friends!!
I am new to the field of CFD and am working on a project related to airfoils.For this I have to draw different-different airfoil geometries in Ansys and make comparision between these airfoils in order to get highest Coefficient of power out of them. While doing study regarding this, I got to know that I will have to import the coordinates in ANSYS and then those regular meshing and postprocessing. Is it true?? If then how??
SHIKHA BHUYAN is offline   Reply With Quote
Old   August 10, 2013, 13:43
Default Airfoil coordinate
shikha
Have got some idea.I vl hav 2 make excel sheet and prepare AIRFOIL data there.
Old   August 16, 2013, 05:30
Błażej Popławski
blazejpop is on a distinguished road
Hi.
Here you got some airfoil data base:
http://m-selig.ae.illinois.edu/ads/c..._database.html
You can import coordinate files in Workbench Desugn Modeler by tool: 3D Curve.
It's in 'Concept' tab i think.
blazejpop is offline   Reply With Quote
Old   August 18, 2013, 02:48
Default Airfoil design
shikha
Thanx...I did this...but few coordinate files are not read by 3D crurve. Howevr, its points can be imported. I hv 2 join these points in order to get the complete profile. But I think sketching lines between the points wnt serve the purpose..vl it or der ny other option???
Old   August 21, 2013, 11:50
Bruno
brunoc is on a distinguished road
You can import your points using the 3D Curve option and then sweep it in its normal direction. The only thing you'll need to do before that is format your points according to what DM expects. You can find the correct file format in the DM documentation.
PS: Please don't use chatroom lingo to post here. It makes your text really hard to understand for those of us who don't have english as their first language.
brunoc is offline   Reply With Quote
Problem with airfoil shape optimization robyTKD SU2 Shape Design 7 March 7, 2022 16:18
[DesignModeler] Error at loading airfoil coordinates into ANSYS DesignModeler mix ANSYS Meshing & Geometry 4 October 12, 2014 07:02
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 09:26
Calculating polars from 2D airfoil coordinates... wlvrn Main CFD Forum 0 August 18, 2010 18:43
Airfoil Coordinates Usman Main CFD Forum 7 January 24, 2008 06:53
