Weird problem in FLUENT Species Transport
Old   September 24, 2013, 20:41
Default Weird problem in FLUENT Species Transport
Bin
Chan Hiang Bin
Bin is on a distinguished road
Hi all,
As mentioned in the title, I encountered a 'weird' problem when simulating multiphase+species transport. Originally, I tried simulating tank filled by fluid by turning on multiphase model and all things look well. Then I turned on species transport model to change the input fluid into certain mixture of fluid, other settings remain the same. I ran the simulation, but the result's contour shows the mixture is flowing upward(!). The gravity is -9.81m/s2 which I think is correct (and previous multiphase simulation is correct with -9.81m/s2). I had attached the image here, anyone know what happened?
Attachment 25610
Regards,
Bin
Bin is offline   Reply With Quote
Modelling Biomass Combustion via Species Transport Racheal FLUENT 39 January 8, 2022 07:42
Fluent - license problem. Marcin FLUENT 3 April 13, 2018 16:33
Species order fluent Raddi FLUENT 1 March 13, 2009 00:21
Species Transport with Multiphase flow in FBR venkat FLUENT 1 July 23, 2008 23:53
Can Fluent handle species transport in multi-phase Roger FLUENT 1 January 30, 2003 19:12
