Home > Forums > Software User Forums > ANSYS
A problem about Fluent reference value
Old   November 1, 2013, 03:33
Default A problem about Fluent reference value
Yao Lu
shuoxue is on a distinguished road
I'm solving a 3D flow around a circular cylinder case with air dielectric and LES model. However, the drag coefficient of cylinder wall doesn't match the value announced on papers.
Reference value is set as follows:
length = diameter of cylinder
area = diameter * height of cylinder; for 2D case, diameter of cylinder
velocity = velocity of inlet
viscosity = viscosity of air
Are they right or wrong?
Thanks in advance.
shuoxue is offline   Reply With Quote
Old   November 1, 2013, 05:51
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
There is not necessarily a right or wrong when it comes to reference values.
The ones you have are an obvious choice, but someone else might find the surface of the cylinder more appropriate than the projected surface for the area reference value...
Since you are comparing your results to those in some papers, you simply take the same reference values as reported in these papers.
If they give coefficient values without stating the reference values used to obtain them, I would start searching for other sources to compare your results.
flotus1 is offline   Reply With Quote
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
It would be wonderful if a tool for FoamToTecplot is available luckyluke OpenFOAM Post-Processing 165 November 27, 2012 06:54
Installing OpenFOAM-1.5-dev on a cluster ZKM OpenFOAM Installation 4 December 25, 2010 15:59
Compiling new Solver with wmake lin123 OpenFOAM 3 April 13, 2010 14:18
Windows Installation BugsComments on Petrbs patch brooksmoses OpenFOAM Installation 48 April 16, 2006 00:20
