Importing solid works 2D drawing to Ansys
Old   January 6, 2014, 01:58
Default Importing solid works 2D drawing to Ansys
Anvesh
Agad15 is on a distinguished road
I am new to using Ansys. I have a problem in importing a 2D drawing to Ansys design modler (I created geometry in solid works) in work bench. It is showing
" No valid bodies found"
when i was trying to import.
Please help...
Thank you.
Agad15 is offline   Reply With Quote
Old   January 16, 2014, 11:29
Default convert to surface
Nabeel
Nabeelg is on a distinguished road
the best way is to change your 2d graph into surface while you are in solidworks, and then you can import to ansys / fluent.
Nabeelg is offline   Reply With Quote
2d file, import, solid works
[DesignModeler] How to avoid duplicate faces when Importing from GAMBIT to ANSYS 14 yahya ANSYS Meshing & Geometry 0 December 17, 2012 10:15
[ANSYS Meshing] Importing a model from GAMBIT to ANSYS 14 yahya ANSYS Meshing & Geometry 0 December 14, 2012 04:03
[DesignModeler] Importing Solid Edge ST4 Geometry into Ansys Fluent 13.0 for meshing The Mighty Rearranger ANSYS Meshing & Geometry 0 November 27, 2012 12:44
importing mesh from Gambit and other software to ansys workbench mortazavi ANSYS Meshing & Geometry 5 June 6, 2011 11:09
importing mesh to ansys workbench??? mortazavi ANSYS 0 June 1, 2009 05:10
