simple 2d open ended cylinder with moving piston: dynamic meshing query
Old   January 6, 2014, 09:55
Question simple 2d open ended cylinder with moving piston: dynamic meshing query
Lisa Marfell
lmarf88 is on a distinguished road
I am looking to do a 2D model of a moving piston in an open ended cylinder of constant diameter. I have seen relevant examples and they seem to use dynamic meshing, simulating the piston as a moving wall/ boundary condition. After reading through the Fluent manuals, I think that the layering scheme is sufficient for this simple problem. However, I am unsure of how to create a dynamic mesh zone to select which wall will be moving.
When I try to create a dynamic mesh zone it says there motion UDF/ profile is not specified. Do I have to write UDF code in order to create a dynamic mesh zone or is there a simpler way of doing this?
I have attached a screenshot of my issue.
Thanks in advance,
Lisa
lmarf88 is offline   Reply With Quote
Dynamic mesh simple moving DonQuijote Fluent UDF and Scheme Programming 7 November 14, 2012 19:57
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 06:54
Dynamic Mesh moving interface help akash.iitb FLUENT 0 August 23, 2010 23:53
dynamic meshing, rotating moving mesh...... madhan FLUENT 1 January 23, 2007 23:55
moving cylinder blur boy Main CFD Forum 4 October 12, 2001 05:32
