Two way FSI negative cell volume in static analysis
Hey there,
I tried to set up a 2 way FSI for an elastic body with surrounding water flow. However, Fluent crashes because of negative cell volume. From my research, I know that decreasing the time step should help but since I am working with Static Structural and Steady Analysis in Fluent, there is no such thing as a time step. Are there any other things I could do? I am using an unstructured Tet Mesh with inflation layers of the magnitude 10e-4m for a realizable k-epsilon model. Thank you! Steven |
Is there really nobody who can help me?
I tried switching to transient as it is written that using smaller timesteps could improve the performance. Unfortunately, that does not change anything. I tried running the simulation with air instead of water and there were no errors. I guess that's due to the smaller deformation. However, I chose to remesh and smooth the tets in tet regions. Is there anything I should change additionally? I'm sure that I'm not the only one facing this kind of problem. |
