Taylor - Couette simulation using CFX
1 Attachment(s)
Hi there, I am fairly new to CFD in general and am running into some troubles
I am currently trying to run a simulation for Taylor Couette flow (in the laminar region). I started off by running it on CFX and managed to get a solution for Circular couette flow but was unable to visualise any Taylor vortices even when I ramped up the speed. After doing some research I believe I have to use CFX Turbogrid in order to be able to plot the radial velocity contours that will allow me to visualise the vortices. However I have run into a complication which is that it doesn't allow me to import my geometry into the Turbogrid Mesh because of the following message:"The upstream blade geometry could not be retrieved. Please verify that the export points feature is specified correctly" When I try to export points in design modeller it requires me define a flowpath and blade geometry - however I don't have any blades. I am a little confused as to whether I should even be using Turbogrid so any help would be appreciated. Thanks EDIT: I have realised now that it is not turbo grid that I should be using but in fact the turbo tab in CFD post. However I am still unable to see any Taylor vortices at Re>100. Is there some trick to this that I am missing, either in CFD post with regards to my plotting tools, or perhaps the mesh generation close to the outer cylinder wall (inner cylinder rotating). |
Hi there
I was wondering if you managed to get solution to this. I am also trying a similar simulation and thought I'd ask here rather than create a new post. I created the geometry for the annular region of the device and then applied a tetrahedron mesh to it. I then set the boundary conditions as follow: 1. upper wall - no slip - stationary 2. lower wall - no slip - stationary 3. inner wall rotating at 10 rad/s (Re approx 1009.4) 4. outer wall - no slip - stationary I ran the simulation and then in the post processing I took a slice through the cylinder and plotted a contour map of the radial velocity but I only get vortices at the top and bottom near the upper and lower walls --> this is what I get http://s1.postimg.org/wztx9si7f/Untitled.jpg Did you manage to sort your simulation out? If so I'd appreciate any help |
