Is there a way to hide wind tunnel/enclosure?
Old   January 13, 2015, 14:19
Default Is there a way to hide wind tunnel/enclosure?
kez
Kieron
kez is on a distinguished road
Hi, I am simulating an aerofoil in a wind tunnel. I have done the simulation and want to see the velocity and pressure distributions on and around the aerofoil. However, the wind tunnel is filled and I cant see the aerofoil to be able to analyse it fully.
Thanks
kez is offline   Reply With Quote
Old   January 13, 2015, 15:17
Tom-Robin Teschner
t.teschner is on a distinguished road
if you go to contours and then hit set up, you can choose on which face you want to display the quantity of interest.
t.teschner is offline   Reply With Quote
Old   January 13, 2015, 16:01
kez
Kieron
Tried that but I can only view the inlet velocity, outlet pressure, interior surrounding surface and wall surrounding surface. The only one which will let me view the aerofoil is the interior surrounding surface, however it comes with the wind tunnel.
I used the boolean option to cut out the section of the aerofoil against the wind tunnel. Does that have something to do with the reason why I cant individually view the side of the aerofoil?
Old   January 13, 2015, 16:25
Tom-Robin Teschner
I see, the problem is that during mesh generation you have to specify each boundary separately (that you want to look at), otherwise fluent (or infact any other post processor) will not be able to figure out by itself what exactly you want to look at. that is true even if they have the same sort of boundary condition (wall in this case).
would you be able to provide the *.cas and *.dat file from fluent to have a look?
Old   January 13, 2015, 16:38
kez
Kieron
The file with the aerofoil and wind tunnel?
Old   January 13, 2015, 16:40
Tom-Robin Teschner
yes, the file when you save the project within fluent (two files, with *.dat and *.cas ending)
Old   January 13, 2015, 17:05
kez
Kieron
I only seem to have the .wbpj file which I open up in workbench.
Any ideas?
Old   January 13, 2015, 17:52
kez
Kieron
I have meshed the aerofoil individually and got a result. However, as you can see from the image there is low velocity where there shouldn't be (blue contours).
Any ideas as to why this is occurring?
Old   January 13, 2015, 18:09
Tom-Robin Teschner
you have a turbulent viscosity warning, which is never a good thing. are you meshing with the workbench meshing tool? have you run the mesh check inside fluent to check the quality? it could also be that the boundary conditions are set up incorrectly. but that is all very difficult to tell without sitting infront of the problem. if you go (inside fluent) to file -> write -> case and data safe the file and upload them somewhere (you can send the link in a private message if you prefer) i could have a look at it
Old   January 13, 2015, 19:06
kez
Kieron
Ok, i couldnt find the file > write etc. so ive put all the files in a folder and compressed them to send.
simulating wind shear profile for a wind turbine--> How??? mohammad CFX 14 August 25, 2014 09:09
FSI - Wind Turbine AUN CFX 13 August 29, 2012 16:44
simulating wind shear profile for a wind turbine--> How??? mohammad FLUENT 0 April 14, 2012 23:54
Simulate the wind profile on a wind turbine---> HOW ???? mohammad Main CFD Forum 0 April 13, 2012 08:16
Simulate the wind profile on a wind turbine---> HOW ???? mohammad Main CFD Forum 0 April 13, 2012 08:07
